Displays the ACL configuration.
There are no arguments or variables for this command.
N/A.
This command displays the state of the ACL configuration, set by the following commands:
enable access-list refresh blackhole
enable access-list permit to-cpu
configure access-list rule-compression port-counters
configure access-list vlan-acl-precedence
The following command displays the state of the ACL configuration:
show access-list configuration
On a series switches, the output from this command is similar to the following:
Access-list Refresh Blackhole: Enabled Access-list Permit To-CPU: Enabled Access-list configured vlan-acl precedence mode: Dedicated or Shared Access-list operational vlan-acl-precedence mode: Dedicated or Shared Access-list Rule-compression Port-counters: Dedicated or Shared
The following displays how the output looks when "multiple matches" action resolution mode is chosen:
Access-list Refresh Blackhole: Enabled Access-list configured vlan-acl-precedence mode: Dedicated Access-list operational vlan-acl-precedence mode: Dedicated Access-list Rule-compression Port-counters: Dedicated Access-list Action Resolution: Multiple
The following displays how the output looks when "highest priority only" action resolution mode is chosen:
Access-list Refresh Blackhole: Enabled Access-list configured vlan-acl-precedence mode: Dedicated Access-list operational vlan-acl-precedence mode: Dedicated Access-list Rule-compression Port-counters: Dedicated Access-list Action Resolution: Highest Priority Only
show config acl # # Module acl configuration. # configure access-list action-resolution highest-priority
This command was first available in ExtremeXOS 11.0.
The Access-list Permit to CPU configuration was added in ExtremeXOS 11.3.2.
The Access-list Rule-compression Port Counters configuration was added in ExtremeXOS 12.3.
The Access-list Configured VLAN-ACL Precedence Mode configuration was added in ExtremeXOS 12.3.
